The pavers (not sure if brick or clay) under our patio are starting to become uneven in a few areas and several pavers have a white residue. I'd like to lift up the pavers to level the ground again and re-lay then give a pressure wash clean (unless its better to pressure wash first?).
What tools will I need to repair the uneven pavers (level, straight edge, tamper, sand)? Are there any tricks to remember the pattern so that I don't stuff it up?
I'm getting the impression that while I only intend to pull up a 1x1m area that will probably blow out as I notice adjacent pavers needing a little adjust too.
I'm not sure what the white marks on the pavers are from so if it can't be cleaned could I also just flip them over?
I was wondering if I pressure wash last will that undo some of the work when placing the tiles, and instead that could be a first step then a gentle wash last?
