How to make a support for cucumber like plants along the wall
Hi @shankor,
Can you please let us know which wall you plan to grow your creeper on? Are you referring to the brick wall or the fence panel? If it's the latter, can you please tell us what material they are? It will affect what fixing methods are used.
Thanks,
Fence wall
it’s a metal carbon steel magnet sticks
Hello @shankor
If you are installing it on your Colorbond fence, I suggest using 70x 35 and mounting them top and bottom on the posts of your fence, I recommend using self-tapping steel screws to hold them in place. Please do not screw through the fencing panel as it will become a hazard to the person on the other side of the fence. I suggest using Jack 1800 x 1000 x 200 x 7mm Reinforcing Mesh Sheet as a climbing frame for your cucumbers. Mount the mesh onto the timber pieces and secure with screws.
I also suggest having a look at this discussion - How to install a Matrix Decor screen to Colorbond fence by @firenevac.
