Hi all,
I am wanting to mount a communications cabinet in one of my cupboards to put my networking gear. Currently it's on top of a shelf but it's causing the shelf to droop.
I've found two studs in the wall (one in the centre, and one right on the corner of the plaster) but the stud spacing is too wide for the mounting holes on the communications cabinet (https://www.selby.com.au/brands/raxx/8u-wall-cabinet-530-450.html). Based on this, I assume my best option is to somehow span the gap between the two studs with another material and then mount the cabinet to that. But I'm not sure the best way to do it! Can someone suggest the best material to attach to the two studs? I've seen people suggesting plywood and also pine. Furthermore, can anyone recommend the best screws to use to attach to the other material to the studs?
Thanks in advance!
