What's the best way to seal these kitchen cupboard holes so that insects etc can't get in?
Hello @Else,
I propose using Kinetic 295 x 210mm White Flat Self Adhesive Cover Plate in combination with Parfix 340g Expanding Foam Filler.
The general steps will be to cut some cardboard and prepare a stencil of the area you wish to cover. The cardboard will serve as a guide when cutting the laminate cover plate. Once you have one side installed, use the expanding foam to fill the empty middle part, then cover that spot with another cover plate. Please remember that the expanding foam can be cut down with a snap knife.
Thanks Eric!
