Hi Everyone
I have accidentally peeled the paint layer on the walls as per images and would need help on how can I fix it myself.
Regards
Welcome to the Bunnings Workshop community @Sunie. It's fabulous to have you join us, and many thanks for your question about repairing a wall.To repair this, you'll need to start by sanding the area where the paint and paper layer have torn to remove any loose edges and create a smooth transition with 220-grit sandpaper. Once that's done, apply a skim coat of plaster filler over the damaged section.
After the filler dries completely, sand it back until it's flush with the surrounding wall with the 220-grit. Then apply a suitable plasterboard primer to ensure good paint adhesion and prevent future peeling. Once primed and it's dry, you're ready to repaint.Please let me know if you have any questions.Mitchell
