Hi there,
I'm working on renovating my bathroom as we know the shower is leaking via tiles and grout (assessment via plumber), the bathroom is from the 60's with no waterproofing and hasn't been updated since.
We used a moisture reader to asses the walls and weirdly found a lot of moisture in the wall opposite to the shower, not directly in the wet area, that wall is opposite to a separate toilet.
The moisture was only high in the tiled area up to approx 1.2m, the upper part of the wall with no tiles is dry.
We removed some tiles and render to asses the situation and let the wall dry before we can apply waterproofing and render the wall but I can't seem to understand where the moisture comes from as there is no pipe running behind that wall.
Could it be condensation trapped behind the tiles?
Thanks for your help 🙂
