I have a double concrete driveway with street curb and guttering. The front edge of the drive where it joins the roadside has cracked away when a road maintenance crew was doing work along the road (although they deny it despite CCTV footage of their mini excavator driving right up to the edge in the area of the damage).
Anyhow the front edge where it joins the road with a size of approx 8 - 12 cm back from the road and length of approx 20cm has broken away. The driveway itself seems to have been made in two layers (at least in this section) where the top layer which is approx 3cm deep broke away but the lower level concrete is still in place and smooth.
Getting a concreter to do this I am sure will cost quite a few hundred and for a small job figure at least try DIY first. As vehicles drive over it and it is the road side edge figure I need to prevent shear like forces acting on it. I was thinking one way of doing this is perhaps to use something like
https://www.bunnings.com.au/strol-0-5m-pebblelock-permeable-pavers_p0215399
or
https://www.bunnings.com.au/strol-0-5m-surepave-plastic-pavers_p3452192
and could then anchor this into the base concrete and cut it down to the required size. Then utilise a concrete mix to shape and form it smooth to existing curb entry. Finally once complete then paint it to match the rest of the driveway.
My query is, Is what I am thinking a valid plan or is there a better product or method suggestion
