just wanting some advice, could the discolouration on the leaf be from dryness/too wet or somr sort of fungal thing?
Hi @laurat1989,
Thanks for the photo. The browning and discolouration on your Magnolia leaf appears most likely to be caused by environmental stress rather than a fungal issue. This type of damage is commonly associated with water-related stress, either too little or too much. If the plant has experienced dry periods or inconsistent watering, the leaf tips and edges can brown and die back in this way. On the other hand, overly wet or poorly draining soil can also cause root stress, which may present similar symptoms.
The mulch around the base of your plant is great for conserving moisture, but it’s important to ensure the soil beneath isn’t staying too soggy. Additionally, leaf scorch from hot sun or drying winds can cause this kind of browning, especially on young or exposed foliage. If your area has recently had a frost or cold snap, that could also cause leaf damage.
While it doesn’t appear fungal at this stage, continue to monitor for any spreading, spotting, or fuzzy growth, which would be indicators of a fungal issue. Otherwise, focus on maintaining consistent moisture in well-draining soil, and your plant should recover well.
Just thought I'd add that the Bunnings guide Growing, pruning and caring for magnolia trees might be helpful for you caring for your plant.
