Hello friends,
Hoping you have some advice for my latest DIY home renovation problem. I am installing kitchen cabinetry. I have an L shaped kitchen (or will have) and have successfully installed the suspension rail on one side. I have measured up the the other side and made the discovery that thanks to a particularly thick mortar line 3 of 6 attachment points line up with a horizontal mortar line. Yes, I did check this but i mistakenly didn't measure the whole way along the wall. To avoid the mortar line and drill directly. into the brick would mean moving the rail up 2cm. This is doable but then I would have to re attach the already installed rail - which I am happy to do BUT if I move it 2cm to be level with the yet to be installed rail - the attachment points will align with a mortar line on that wall. In sum, it seems I cannot avoid having attachment points in the mortar. Is there something I can fill the drilled holes with, or put into the drilled holes before putting in my masonry anchors that will reinforce the mortar? It doesn't matter where I put the attachment points along the rail half of them will overlap the mortar.
I have used 75mm x 6mm masonry ankascrews to attach the first rail with the help of horseshoe shims. The cabinets will obviously have weight in them. I will put in a wooden support underneath the cabinets for additional supports but also need the screws to hold into the wall. The wall is double brick if that makes a difference,
offending grout line in highlighted box
The succesfully installed rail
