Hi All
Looking for advice on the best way to build a timber shade arbour/micro pergola using a diy kit. It’s going on a structural slab approved by council during our house build. I’ve also reviewed the building & council codes and this will be built small enough not to need approval.
I’ve watched several deck & pergola builds from the community here and been through most of the posts but have some project specific questions….. I’ve done general D.I.Y. over the years but nothing this ‘structural’ so would appreciate some advice.
It's a simple open top design to create privacy from neighbours and shade from the western sun. (Note that this is the courtyard that opens from the master bedroom so we want something more than a shade sail for this space). I will potentially add a timber screen or bamboo thatching on the roof and back side. The proposed size is 2000mm high, 2500-4000mm long and 1600mm wide/deep;
1. Is a single lean to structure robust enough (diagram 1) or should I go for a 3 post lean to model (diagram 3)? I’ve also included a 4 post option if affixing to the wall is recommended (diagram 2)?
2. I have 3 types of exterior wall to affix beams. Option A) the grey axon JH FC cladding, Option B) white cladding over header above the door or C) the bricks? I’ve included photos of the above options plus the framing of this area taken during our build. The FC cladding looks easiest but would the brick offer greater support?
3. The slab is rated as structural and 200mm + deep. Given the fence behind has some give and this side of the house is exposed to western sun all day and direct wind/weather, I think the slab will provide better structural support. Given the position, we were intending on anchoring the posts directly to the slab using a base plate/stirrup. Will this be a strong enough alternative rather than the dig & set method?
If you’ve made it this far (thank you!) advice on any of the above is greatly appreciated. I’ll order suggested treated pine and kit once we have a final plan.
Thank you
Erin
