Tuscan Path 1.2m x 8cm Roman Stone Edging - Bunnings Australia
I've tried a hacksaw and its taking forever and bent the saw
Hi @BlairL,
Since the stone edging from Tuscan path is rubber, it can be cut with a standard hand saw. Here's a helpful video installation guide.
A hacksaw is typically designed for metal and has very small teeth, which could be why it's taking so long to cut. If the hand saw doesn't work for you, you can also use a jigsaw.
