Hello, I am looking for an outdoor hinge for a swing gate on a metal post. Is the below product suitable for this. https://www.bunnings.com.au/zenith-100mm-matte-black-gate-radius-hinge-2-pack_p0131446
Hello @sred
Yes, you can use the Zenith 100mm Matte Black Gate Radius Hinge - 2 Pack on a metal post. Please keep in mind that this is a medium duty gate hinge and will not be able to hold a heavy gate. For heavy gates, I suggest Austyle 100 x 100 x 2.5mm Black Heavy-Duty Hinge which is capable of holding a 40kg gate when using two hinges together.
Thanks Eric.
What about the below one, is it suitable for outdoor gate.
https://www.bunnings.com.au/austyle-100-x-75-x-2-5mm-316-marine-grade-stainless-steel-hinge-fixed-pin-ea-45216_p0119738
Yes, the Austyle 100 x 75 x 2.5mm 316 Marine Grade Stainless Steel Hinge Fixed Pin will work just as well. It is definitely suitable for outdoor use.
Thanks Eric. Will the screws that comes with this product be suitable for an outdoor metal gate?
Hi @sred
The hinges don't come with its own screws; you'll need to choose ones that are suitable for your needs. I propose going to the store to make sure you get the right sized screws for the hinges.
