Looking to follow manufacturers instructions , could you please advise what 10mm foam,etc I can use as per attached picture to pack perimeter?
Thanks
Hi @Taco,
Thank you for your question.
I'd suggest using this Sika 10mm x 50m Abelrod Gap Filler, which is a foam filler rod often used to fill expansion gaps such as this.
It will allow for slight expansion of the materials while blocking updrafts and dust coming through the gap.
