Dear Bunnings Community,
I am planning two small deck projects for which I wanted to seek your input - thanks in advance.
Great to see the existing support available here: https://www.workshop.bunnings.com.au/t5/How-To/How-to-build-a-low-level-deck/ba-p/45715 and https://www.workshop.bunnings.com.au/t5/How-To/How-to-build-a-deck/ba-p/102739
Project 1. Low level deck on concrete slab of my front porch:
The porch is 5.2m x 1.5m. The height from the concrete slab to door frame is 135mm. I wanted to have a composite deck (140 x 24mm) on the concrete slab to have the deck level to the door frame. Leaving the deck board thickness of 24mm out, I would have only 111mm for the deck frame.
Questions:
- Is this a good plan to have a deck here (wife really wants to have one 🙂 )?
- If possible to have a deck, can I please pick your brain on selecting the frame timbers' dimensions, and how to create a gap between the frame timbers and the concrete slab?
Project 2. Deck stairs:
From footpath to my front porch is 4m long and 1m in height. I want to have deck stairs about 2m wide. The natural ground is sloped from porch to the footpath. I am planning to have 7 treads @143mm rise each of composite deck (140x24mm), each tread supported on a box, which is connected to a post dug in ground (please see diagram). The two sides of the stairs have existing brick walls for landscaping.
Questions:
- Any issues with the plan? 🙂
- How many posts per box (I planned 6 @0.5m spacing - see diagram) - sufficient, or overdoing it or there are better alternative plans?
- What size bearer, joist, and blocking to be used in each box?
Thanks heaps.
Regards
Nath
