Hi, we have small (170l) heat pump hot water system which has been working fine for a number of years. However in the middle of a Canberra winter it takes a lot longer to warm up and I'm investigating fitting additional insulation to it.
The problem is that the unit is outside and not under cover (eaves etc). I'm concerned that putting insulation around it would create a trap for rain water between the blanket and the tank leading to corrosion. Is there any alternative to fitting say a wooden cover around and above the unit?
Also more generally, can there be problems with condensaition between the blanket and the tank?
Many thanks,
Malcolm Street, Fraser ACT.
