Hello Community
Please kindly advise, What l can use to fill the concrete planter box and what type of soil should l use?
Plants recommendations will be greatly appreciated.
Thanks
Regards.
Hi @Bea12,
Thanks for your question. You might find it helpful to read through this guide on How to fill a raised garden bed, which outlines the process and explains what materials are best to use. It covers suitable filling layers like organic matter, soil blends and potting mixes, which would apply just as well to your concrete planter box.
As for plant recommendations, there are so many options depending on the look you’re after. If you can let us know more about what you’re hoping to achieve — whether you’d like something lush and tropical, colourful and full of flowers, or tall enough to provide privacy or block a view — we can help tailor suggestions to suit. It would also be great to know your approximate location, so we can recommend plants that are best suited to your local climate and conditions.
Based on its size, modern finish and what appears to be a full sun position (judging by the open surroundings), here are some plant suggestions that would suit a clean, contemporary look and thrive in many Australian climates:
Tall feature/back layer (for height and structure):
Mid-height fillers (for texture and body):
Trailing/front edge plants (to soften the edge):
