Hello,
Looking for advice on what to use to fill in small cracks or gaps on my pavers. Thank you.
Regards,
Floyd
Hello @Floyd25
It appears that the grout on your pavers have begun to crack and deteriorate. I recommend using a multitool with a grout blade to remove the old grout. I propose using Dunlop 5kg Flexible Coloured Grout to replace them. I suggest using Gripset Betta 1L Concrete Crack Filler to fill in the cracks in your pavers.
Thanks @EricL.Can I also paint or seal or waterproof the the whole area? Total area is around 2sqm.
Kind Regards,
Norman
Yes, after repairing all the cracks and replacing the grout lines you can paint the surface with - Berger Jet Dry 4L Heavy Duty Deep Charcoal Paving Paint. I also suggest looking at this discussion - Paver refresh with paint by @Peggers.
@EricL Thank you!
