I want to purchase a bamboo benchtop for my kitchen from Bunnings. Do I need to put a varnish on the the surface of the bamboo bench top?
Hi @karenclancy,
I am assuming you've purchased a Kaboodle Bamboo Benchtop, which will require a coating, such as varnish, to finalise the installation.
You can use a clear varnish product such as this Cabot's Clear Benchtop Timber Finish, or you can use an oil such as this Kaboodle Clear Hardwax Oil.
You'll want to give the benchtop a light sand with some 120 Grit Sandpaper to remove any minor imperfections that could have occurred between manufacture and installation. Nothing crazy, just a light sand.
Once sanded, brush off any sawdust and wipe the bench down with a lightly damp cloth.
You can then apply 2-3 coats of your chosen finish following the manufacturer's instructions for application closely.
Check out Applying Clear Hard Wax Oil To Benchtops for some guidance.
