I have a staircase from lounger to bedroom. Aside from the strings it is MDF. Until now it has been carpeted and I hate carpet.
Can I varnish MDF? I bought some Cabot CFP oil varnish but then thought maybe I should verify it is OK to do since MDF is wood particles stuck together and maybe solvents in it might damage the MDF. It used to be said that you should treat the underside of a table the same as the top side as differential air moisture absorption could cause it to warp. Anything i need to do on that?
I also want to remove water paint from the strings what is least effort to achieve this? Can a hot air gun hep?
Thanks in advance.
