I am planning to build a low lying deck in my backyard, I have looked through previous information provided on building low lying decks such as How to plan out a deck and How to build a low lying deck. I have put together a sketch below and I wanted to check if everything is ok and ask a couple of questions.
It will be 6m x 4.6m, with the 6m side along the side of the house and the decking boards will be laid perpendicular to the house side. For the joists I am planning on using H3 90x45 (to minimise the finished deck height) and using tuff blocks rather than poles and cemented in. I have a 300mm overhang on each side and 400mm joist spacing. The tuff blocks will be spaced 300mm in from the end, then 1350mm between them. (from what I can tell the span table shows for 90x45 a continuous of 1800 for 400mm joists so I have extra to spare). In between each of the tuff blocks I will also do a bridging piece of 90x45 timber between each of the joists. Is there anything wrong with my timber sizing/spacing/supports?
It will be placed on top of soil (currently has pavers there, but will need to be removed for height reasons so that top of decking is flush with walking out of house. I will need to make sure there is still a fall away from the house for drainage, and then put something under each of the tuff blocks to make them level - what is suggested here, road base? Also I do worry about weeds going in the soil over time (cause they seem to grow easily in rock garden bed etc) should I be putting some sort of weed matting down underneath?
Lastly I was originally doing at longer than 6m, but sticking with the longest length of timber available. If I was to try and make it longer, whilst keeping the orientation this way, how would I join the two joists together? Would they join on top of a tuff block?
Is there anything else I haven't considered and/or something I could do to make it easier or better?
Thanks in advance
Ben
