What is the best way to connect the discharge outlet of a sump pump (e.g. 25mm - yet to buy it) to tee into a 90mm stormwater pipe?
The sump container is under the house in the crawl space collecting built up water from a French drain along the footings.
The 25mm outlet line will be run through the brickwork and run down towards the nearest downpipe
