I'm trying to tackle a DIY project in my garage and could really use some expert advice. There's a noticeable gap between the brick wall and the concrete floor, and I'm looking for the best way to seal it up.
It's about a 5 mm or less gap in most places, and I'm keen to stop any drafts, dust, and especially critters from making their way in. I've seen a few options floating around, like using backer rod with polyurethane sealant, or even just some kind of self-levelling sealant directly or with skirting board.
What's worked well for you in similar situations? Are there specific products or techniques you'd highly recommend for sealing this kind of gap in a garage environment (i.e., one with potential for movement, temperature changes, and possibly some moisture)?
Any tips on prep work, application, or things to avoid would be hugely appreciated!
Thanks in advance for your wisdom!
