Hi, I am planning on building a deck that is 2.5m x 5.5m and runs between the house and a besser block wall. It non-trivial to install stumps in the area so I was hoping to attach the bearers directly to the two walls and then run the joist between them.
Firstly, will that work, and if I am using 140x45 bearers do I need to jsut ensure that it its supported by the wall according to the span table (i.e. every 1.4m)?
Secondly, what is the best way to affix the bearer to the walls, one side is solid clay brick or solid concrete, while the other side may be hollow besser bricks (may be concrete filled..). I was thinking 16mmx140mm Dynabolts directly into the brick, but didn't know if that would work into besser blocks. Any advice?
