The paint is peeling off the top inside my electric fan-forced oven. I was planning on sanding off the remaining bits of paint and then repainting.
Would either of these paints be good for painting the inside of an oven?
https://www.bunnings.com.au/white-knight-300g-metallic-charcoal-hi-temp-spray-paint_p1560431
https://www.bunnings.com.au/scandia-400g-metallic-black-high-temp-enamel_p3171529
Cheers,
HGK
Hi @HGK,
I imagine both would be fine, but of the two options, I would suggest using the White Knight Metallic Charcoal Hi Temp Spray Paint, mainly because it specifically mentions it can be used on ovens.
Have a look at White Knight® Hi Temp for the instructions for use.
The basic process is to lightly sand the surface, like you were already planning to do, then wipe it down with mineral turpentine, then allowing it to fully dry before painting.
Thank you, Jacob!
