Which sealant is best and affordable to fill gap between brick wall and concrete floor? Concrete expanded with time and left gap between wall and floor.
Hi @vaishp,
Welcome to the Bunnings Workshop community and thank you for your question.
Assuming this is on the outside of your home, this is a fairly common occurrence, which can be fixed using abelrod in a suitable diameter for the gap, then covering it with Sikaflex 11FC Purform in a colour of your choosing.
Check out How to fill a joint in a concrete slab for an example of how this is done. The situation in the article is different, but the materials and process are the same.
If this is not similar to the situation you are dealing with, please let me know so I can assist further.
