Do you have to use a joiner between every sheet when installing Wall Art wet Area Wall Panels or do they butt up to each other?
Hello @Smitho1
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about Wall Art panels.
Yes, the Wall Art panels can be joined together using the approved joining method.
Silicone Joins:
WallART Linear can be installed using a butt join system rather than the matching joining strips. If you choose to do this, apply bond breaker tape to the timber frame at the centre of the join before fixing the sheet to the wall. Leave a 3mm gap between the sheets using an off cut as a spacer. Run masking tape down the sides of each join and fill with a matching bathroom silicone. Trowel off any surplus and remove masking tape. Wipe off any excess silicone on the surfaces using a damp cloth or mineral turpentine.
I've emailed you the WallART installation brochure which has further details.
Hi EricL,
Could you please email me the WallArt installation brochure too? Thank you.
Hi @Kim3110,
The WallArt installation guide can be found here - WallART Brochure.
Let me know if there is anything else I can assist with.
