Pine and Plywood were combined to create a Herringbone patterned sliding timber barn door.
The project
Feature barn door. Wife wanted a herringbone barn door to separate the kids retreat from the main living and dining area. The design phase went as follows: Measure the area I need to cover. Do a rough drawing for the door to confirm sizes. Confirm how the door is going to hang off the wall - we had to get a 4.5m piece of wood as a backer to hang the door off. Do a comparison of buying and making it - cheaper to make it. Get as much of the wood cut to size at Bunnings to save you time at home.
Steps
Step 1
Order and collect the materials - order the rails.
Purchase materials.
Step 2
Create the frame of the door - got these cut to size at Bunnings to reduce the work at home.
Step 3
Flip and get the centre of the arrow.
Step 4
Finish the arrow.
Step 5
Finish the rest of the design, trim all the hanging pieces, fill in the nail holes with wood putty and sand to 240.
Step 6
Flip and complete the easy side, fill and sand again.
Step 7
Complete the first stain - three in total. Sand back to wood due to some unevenness with the stain.
Step 8
Complete two more coats of the stain with sanding in-between coats. Used a thin Pine for the ends. We did a 2mm line at the bottom of the door for the runner. I got a 4.5m long piece of Pine at 45mm wide painted it white and used that as the runner mount. Measured the height of the door - height of the runner and the total height including the runners attached to the door. Mounted the rail and hooked the door in.
Step 9
Door complete, the other side has a handle.
Tools and materials
Tools used in the project:
[article footer]
More inspiration for your barn door
Bunnings Workshop member peta gave a modern twist to the rustic look with their homemade barn doors.
Community member LePallet created wide hardwood barn doors by joining two barn doors together.
Get more ideas from our Top 10 most popular barn door projects, 10 ways to build a barn door, and a selection of Barn door ideas for your home.
[article footer]
