Looking at advice for the best sander and dust extraction vacuum, that i can connect Together. This would be specifically for upcycling furniture.
Hi @ttaipari,
The word best is a bit subjective because there are so many options, and it's more important that the products are the best fit for you.
Generally, for woodworking of this nature, I would suggest looking at a random orbital sander and an M-class dust extractor.
If you are looking for the pinnacle of woodworking tools that all woodworkers, me included, would love to have, there's not much better than the Festool ROTEX Orbital Sander 90mm and Festool CTM MIDI 15l M Class Dust Extractor which are available through our friends at Tool Kit Depot. Obviously, at that price point, it's not a reasonable option for most people, but I thought it was worth mentioning.
A step down from this would be a trade quality brand, such as Dewalt, who have a Random Orbital Sander that is directly compatible with their options for both M-Class and H-Class dust extractors.
You then have Ryobi on the more affordable end with their Ryobi 18V ONE+ Random Orbital Sander RROS18 and Ryobi 1500W 30L Wet And Dry M Class Vacuum.
The truth is, there are too many options for me to list them all. Most brands of sanders are compatible with most vacuums, if not directly, then with the use of a Dust Extractor Vacuum Accessory.
I think it is important to have a look at the options available, weigh up the cost and make a selection that is best for you.
Allow me to tag @Nailbag, who is a veteran of the power tool industry, to see what he recommends.
It would also be worth checking out How To Choose A Sander for some general information.
Let me know what you think, and if you have further questions, please don't hesitate to ask.
Hi @ttaipari
I think the most applicable comment b y @JacobZ is the options are vast. There are few things to consider to get the ball rolling:
Sanders are one of the few power tools that are used for extended periods of time. Users often state that they hardly will use the sander. Which is fine, but when they do it could be for a couple of hours at a time. This typically means the motor is heating up without a rest. This is called duty cycle. (Runtime vs rest time). DIY models have a much shorter duty cycle than trade quality. Corded tools in any brand have a shorter duty cycle than "Brushless" cordless. But limited to battery run time. Personally I am 100% cordless with all my tools and have been for a decade or more with exception of my pressure washer. Even my workshop vac is cordless.
So the first question is . . .
1. How often do you intend to use these tools? This determines price point as in DIY or trade. Trade will have those extra features and fine attention to detail making them more user friendly and efficient to use. But it comes at a cost.
2. Budget? If you are like me, I like to buy the best I can afford because I look after my tools and want it to last. But I still mix and match with tools used all the time vs occasionally. I have trade orbital and ROS, but a Ryobi belt sander because I almost never use it.
3. Cordless or Corded? If cordless are you already in a battery system? If so can you stick to that system and just invest in expanding. Belt sanders are very thirsty and probably the only sander I would recommend corded.
With all that in mind, if your just starting out and unsure how invested you will be, Then start with good quality DIY
With type of sanders to look at, then. I would say potentially all 4 because of your application.
1. Orbital (finishing) 1/4 or 1/2 sheet. These tools will leave tiny swirl marks so hand sanding is required before sanding.
2. Detail Orbital. As above but have smaller pointed footprint.
3. Random Orbital. My Fav. Ultra efficient from course to fine stock removal. Leave very very fine swirl marks. When comparing specs, the smaller the orbital movement in mm the finer the finish.
4. Belt Sander. Very aggressive. Ideal for course rapid stock removal of large flat surfaces only. This is probably the last one I would buy should you ever need it.
Dust extraction.
I wont go in to the detail but all DIY M-Class vacs are not fully M-class compliant. They suck the debris fine, but then you are fully exposed during the emptying process making them essentially a standard vac that has exposed you to harmful debris. But for your purpose, stick with a high-wattage standard model. They are all wet and dry and you will only use dry. The most important thing to consider when looking at sanders is whats their ability to connect to dust extraction? Surprisingly both DIY brands have the same extraction size tube across their own models. Which means without an adaptor they wont even connect to their own dust extraction vacs. Where trade will. Powerful (Ryobi) make a universal adaptor that will cross fit pretty much any brand.Hope this gets you started.
Happy to answer more questions to help narrow the search down.Nailbag
