Hi All,
I have an old 3150mm x 5400w timber shed, build from nothing more than 6 ~8-10" posts, with side and top rails. For perspective, from herein I'll be expressing posts etc. as though we're standing on the outside of the shed looking at the front door closed.
About 30 years ago I built the door shown below, with 2x5" hardwood; this proved to be a mistake because being hinged on only one side, the weight of the door is pulling the right hand side post over, and slightly twisting the shed. The roof of the shed has a slant downward from right to left, for rainwater run off. The corrugated iron is screwed on with roofing zips or roofing nails.
So, I need to build new doors, and this time have them open from the middle, and each be hinged to their respective post. The measurements are 3150mm outside to outside of each post, or just under 2860mm inside to inside. I'd love to have metal frames, and bolt some time slats on the inside which I could screw the existing corrugated iron to, otherwise I'll build some timber frames. The existing hinges are the old lift on lift off gate type. I'm happy to look at keeping them, or replacing them with something more secure. Thoughts here please?
Door outside
Door frame
Door hinges
I don't know how I'm going to get the front of the shed pulled back to straight (is this called plumb?), but I could get my neighbour to hook up his Nissan Patrol's winch and ease it back. The issue here is that I then don't know how to brace it. I'm going to lean on you all here.
Please tell me your thoughts. I'm looking for something DIY, strong, and light.
Thanks,
