We would like to build a timber/plaster board wall and door plus door frame installed by ourselves. The wall will be 4250 x 2900.
Thank you for taking your time of consideration and helping.
Kind regards,
Hello @selfwork
Thank you for sharing your question about building a wall and installing a door by yourselves.
I suggest looking at the following guides below:
These guides will give you the basic knowledge on how to build your stud wall and plaster it. The last two guides are to help you install a door jamb and the door itself. You can technically build your door from scratch, but it would be more economical to purchase the door prebuilt with the door jamb kit included. This saves you time and money when installing the door set. If you run into any issues while assembling your stud wall, please don't hesitate to post a question.
Thank you so much for your help. Very appreciated that. It’s very helpful, detailed so that we find it easy to do the work.
