I have purchased the brown-acacia-multi-use-panels and I am keen to know what the stain is so I can purchase to put on the cure area's of the wood.
https://www.bunnings.com.au/specrite-1800-x-600-x-18mm-brown-acacia-multi-use-panel_p0446743
Hello @sjw1au
Please allow us to contact our supplier in regards to the oil used on the timber panel. As soon as we have more information, we'll get back to you.
Thank you for your patience.
Thank you for your patience. The coating applied to these products during the manufacturing process is not something available in-store. However, I can suggest looking at the Cabots Natural decking oil and the Cabots Oil based maple interior stain from the Cabots stains range that should give you a close match. I'd encourage you to speak with our paint experts in-store to see if they can do a test section on your cut ends. Please bear in mind that stains cuts end will always give a slightly difference appearance to a coating applied during the manufacturing process, so it's best to try to face the cut end towards walls if possible.
Thanks for the information.
