I'm in the process of replacing the shower shown with a rail shower, to improve accessibility.
I've already sourced a rail shower that meets the user's requirements. The top end of the rail attaches to the water inlet. The bottom end is fixed with a single screw in the centre.
The mixer is in line with the water outlet, and It suddenly occurred to me that the pipe likely goes straight up through the wall which is right where the screw needs to go. The supplied screw is about 45mm. The wall is single brick. The tiles are porcelain, about 8mm.
How deep is the pipe likely to be in the wall? Is there any way to trace the pipe?
Thanks for any help!
