I have a laundry wall which is fibre cement sheeting, it’s probably about 15-20mm thick, hard to say. I bought two packs of the Ramsay hollow wall anchors that expand and grab the wall from behind.
Well no issue drilling the hole, although the wall feels absolute rock solid like concrete on the surface, once through that the drill is like going through drywall almost. I have put the anchor in, but when i try to turn it, it just spins loosely in the hole. The two little prongs/teeth which are supposed to stop it from spinning do absolutely nothing against the rock hard surface of my wall and if I try to tap them in , it just flattens the prongs altogether. The prongs would be great in drywall but not this surface (Bunnings gave me bad advice in store maybe?)
I can’t use other types of drywall anchor as the wall is so thin, I think my only option now is spring toggle which I was hoping to avoid as the holes are huge and I don’t have that drill bit 😂
any advice on how to get the Ramset hollow wall anchor to expand would be appreciated! I don’t want to have to buy the special tool, I’m just working with the Philips head method Thanks !
