I've just bought a property with no oven. So I purchased a wall oven but was just wondering if a need a cabinet to place it in or not as I've read different options.
As you can see in the images I was thinking of just taking out the frame of the cabinet and place it on that.
Taking out the rear panel there will be 50mm clearance from oven to rear wall. The oven will be on runners about 90mm high so clearance should be fine. If I take out the side panels the will be 25mm space on the left and 40mm space on the right. So if I centre oven the should be around 30mm space either side. The clearance from electric cooktop to top of oven should be 50mm.
Does this sound feasible?
PS sorry for the long post.
