I’m helping a friend close up a door opening, but I’ve noticed the wall studs are 95mm wide instead of the usual standard sizes. Does anyone know where I could source these, or is there a good workaround to match them?
Thanks in advance!
Hi @achintya88,
The simplest way to account for this small variation in thickness is to pack out a standard 90mm stud with some strips of 5mm Masonite.
You can cut them to width using a circular saw and then stick them on with Liquid Nails before attaching your plasterboard or other sheet material over the top.
Hi @achintya88
You can also go to a specialist timber supplier and have them produced to your required size which is unfortunately a service Bunnings do not provide. However if you speak to the special orders/trade counter, they may be able to order some in for you.
Thanks JacobZ, This worked beautifully
Glad to hear it @achintya88.
I hope the rest of your friend's project went smoothly.
