Hi looking for sliding doors with a concealed track similar to the picture below - just want some white doors (not from ceiling level) and need 2 doors that come together wondering if you sell tracks for these and suitable white doors ?
thank you
Hi @fern01,
I’m not aware of any barn doors or track systems that work on the same principle as the one in your photo. All of our barn door tracks are exposed, and our other sliding door track systems use exposed rollers that would require a pelmet to conceal them. Would a cavity slider door be an option for your project, as that provides a fully concealed track and door system?
Let me mention @Dave-1 and @Nailbag to see if they have any thoughts.
Thank you for that clarification we will stick with barn style doors then could you please let me know what type of doors we can use for this? thank you again
Good Morning @fern01
I just did a search to see what style of Barn Doors that Bunnings have Barn Doors Tho I find that going in store and wandering around has given me so many more ideas on what I could do with the doors. Depending on your store they may have some on display, especially in the kitchen display areas.
I would take along the measurements of your opening (width, height plus any edges near the doors of walls) and even sketch out what you have in mind. I find sketching shows up issues/problems that you may run into.
Our full range of barn doors are found on the Bunnings website. What's important with barn doors is that the width of the two doors combined is slightly wider than your opening. So, if the opening is, say, 1850mm, you'd need two 1000mm doors similar to the Hume 2150 x 1000 x 35mm Internal Barn Door Frontier FBDS. The style and look of them is entirely up to you.
It's also important that the doors are slightly taller than your opening.
Hi @fern01
That track system appears to be an Ai generated architectural track design as the actual tracking system is fully concealed which is virtually isn't possible or without massive $$$$
So back to reality and as with @MitchellMc comments there isn't anything that available from Bunnings, other than making your own pelmets to create that more sleek clean finish your after.
Nailbag
For future readers, the hidden hardware doors are called Ghost Barn Doors. Also invisible/hidden track doors,
A number of people use heavy duty drawer runners, but they are visible when the door closes.
Hi @ozgday,
Thank you for sharing your knowledge and experience, I am sure many readers will benefit from knowing what to search for.
