Good afternoon
I purchased a new house 2 years ago and over time the stairs have begun to make a decent amount of movement noise. The noise occurs at pretty much all levels on the stairs. It's pretty consistent and I'm describe it more as creaky than squeaky.
The house is a 2-storey steel frame but the stairs are wooden. In the landing area above the stairs on the second storey, walking around can also cause the same movement sounds on the stairs (plus some metal pinging from the frame). After moving about 2m away from the top of the stairs, walking causes far less movement sounds on the stairs.
I've attached some pictures and am looking for some guidance as to what the cause is and what I can DIY to minimise noise. I do have access to under the stairs if that helps.
Also wondering if anyone can recommend some alternatives to the gripper rods...
Thanks in advance
