Timber moulding and bold wallpaper and paint choices transformed a powder room in a D.I.Y. makeover project.
The project
I transformed our tired powder room into a bold, character-filled space using Bunnings products and plenty of DIY creativity. The room was colour-drenched in rich dark green, with Porta timber moulding adding timeless charm. I wallpapered in a bold safari print for a fun twist, refreshed the existing shelf and hooks with paint, and gave the under-basin fittings a brass glow using spray paint. It’s now one of my favourite little rooms in the house.
Steps
Step 1
Taping and spraying the fittings and hooks. I masked around the vanity fittings and shelf hooks using Scotch Blue masking film and tape. Both were refreshed with two to three coats of White Knights Super Enamel spray in gold.
Taped vanity fittings.
Post final coat.
Step 2
Sanding, surface prep and priming. I sanded the high gloss trims with my orbital sander and hand sanded the walls with 180 grit paper to smooth any imperfections. Then I primed the walls, ceiling and trims in Zinsser Bullseye 123 for a clean even base.
Using my favourite Undercoat Primer.
Step 3
Painting: I first tried a peach but quickly switched to a rich dark green when it didn't suit the space. I painted two coats of Dulux Wash and Wear low sheen on the ceiling and walls, then used Dulux Aqua enamel in the same colour for the trims and shelf for a cohesive look.
Painting over my mistake in colour.
Finished colour drench.
Step 4
Wallpapering. I applied a bold safari wallpaper from ceiling to halfway down the wall, measuring and trimming each panel carefully. Despite the raked ceiling and uneven walls I managed to match the pattern. A proud DIY win.
Carefully matching the wallpaper pattern.
Wallpaper success.
Step 5
Installing the timber moulding. I pre-painted the Porta Timber moulding in the same wall colour, then I measured, mitre cut and installed it using my brad nailer. A quick paint touch-up finished it off neatly.
Neat Porta timber moulding finish.
Step 6
Updating fixtures and styling the space.I swapped the old tap and toilet roll holder for brass fittings and then styled the space with layered textures, warm tones and vintage inspired decor, to complement the dark green and wallpaper.
New brass tap.
Styled powder room.
Tools and materials
Tools used in the project:
[article footer]
More inspiration for your powder room
Bunnings Workshop member EleventhCoastal chose bold green colours for a powder room makeover with Easycraft panels.
Community member diy_hausdesigns chose warm colours for a laundry and powder room renovation.
Get more inspiration from our Top 10 most popular bathroom projects and 10 budget bathroom makeovers.
[article footer]
