I am trying to connect my washing machine pipe to this. I can drill out the barb and attach the hose but my question is can I block the top part (in Red) to prevent water going everywhere. Are there caps available?
Hello @Gumball73
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your sink trap.
I propose using either a Philmac 2" BSP Pipe Plug End which is equivalent to 50mm or the Philmac 1 - 1/2" BSP Pipe Plug End which is equivalent to 40mm. Just make sure to use FIX-A-TAP 12mm x 8m Blue PTFE Thread Seal Tape to prevent leaks. My best advice is to measure the top of the trap to make sure you get the correct size.
