Hi I’m a newbie looking to replace my existing shower head. Am I able to replace it by myself or is a plumber required? How would I go about replacing it, can the existing tap be used and can I replace it with something like this?
https://www.bunnings.com.au/luna-fixed-overhead-shower-wels-4-star-7-5l-min_p0180884?referrer=RetailApp&utm_source=Bunnings&utm_medium=ProductFinder&utm_campaign=SeeReviewsOnline&pid=0180884
Thanks
Hello @DarkBaron
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your shower head.
I suggest having a quick look at this guide - How to change a shower head. It will give you a general idea of how to remove your old shower head and install a new one. I also recommend having a look at the Estilo WELS 3 Star 9L/min Chrome 3 Function Hand Shower Set. It allows you to take the shower head off the wall in order to clean shower itself. I think its a great feature of this unt. But if you prefer a rainhead shower, I recommend having a look at the Estilo WELS 3 Star 9L/min Chrome 3 Function 1/2 Twin Rail Shower Set.
Hi @EricL ,Thank you for the warm welcome and for sharing the guide. It has been most helpful.
A follow up question all our fittings are square shaped. The one recommended is round. Similar square shaped ones has a rail which I think requires some drilling into the tiles? Would the rainwater shower I posted in my initial post not work? Is there anything else I will need to take into consideration? For instance the weight and height of the shower head?
I believe it will work. It may have an extra step or two, but it's not too complex and you should be able to connect it without too much fuss.
@EricL Thanks for your help. Here is a picture of the replaced shower head.
Nice work @DarkBaron.
I hope you are pleased with the new shower head.
Congratulations on a job well done.
Thanks @JacobZ I sure am pleased!
