Hello and thank you in advance for your advice and help with our project.
We currently have solid timber cabinetry in our kitchen and we would like to update it to be a lighter and fresher looking. We really like the solid timber and the profile of the moldings etc, it would be a shame to replace it with a lower quality MDF product so we were thinking of ways to make it lighter. We are seeking advice on If painting over the top is the best option?
We have had several quotes to do 2-Pack but it is very expensive and very permanent.
We have considered doing it ourselves but wondering if the community would talk us out of it, how much prep and work is it going to be? How would we go about doing it ourselves? I have access to a spray gun and I am aware they would need to be cleaned and sanded back properly before applying primer and then 4+ light top coats.
What colour would you recommended the walls are chalkstone (light cream) we are trying to brighten it up.
Would it be worth changing the benchtops over at the same time, I like the sound of Porcelain, currently they are dark green Laminate and have started to sag in places. When the Induction Stove went in the installer said it was about 7mm out and there is a bit rock back and forth so it needed to be packed on one edge, it's still not sitting even.
I'm happy to also change the Sink setup too at the same time as the silicone has failed and there are gaps on the edge. I was going to have to re-seat it anyway and then at the same time I could swap it for something nicer.
Quotes have been around $4-6k for 2-pack paint depending on how much of the dismantling I can do myself (saves about $1500 in labour)
Some Before Photos:
Cupboards Before
Island Front Before
Island Back Before
Some AI generated concept photos:
AI concept Island Bench
AI concept Cupboards
Induction Install:
Induction hob
Thanks!
