Hi Bunnings Workshop community,
I’m trying to replace toilet flush valve and it seems it is stuck somewhere as I can’t undo it. what do you think?
below is the photo of the flush. thanks in advance
Hello @eegoos
If you look closer to the bottom of the flushing valve, you'll notice two black plastic clip on switches one on each side. I suggest investigating those clips and see if they either flip up or down to release the flushing valve.
However, if after several attempts and the clips will not release, I propose engaging the services of a plumber to repair your flushing valve.
Thanks Eric. will do. What would be the replacement for this in Bunnings?
it has trickling water into the bowl and I have followed your steps to identify parts to be replaced, it is actually the rubber. i just need to get into it first 🙂
thanks again
It will be necessary to see the rubber washer underneath so that we can try to identify which seating washer it takes. At the moment I would not hazard a guess as I'm not too familiar with that particular flushing valve.
