Hi, does Bunnings sell the right size piping to connect the IKEA water trap system to the drain?
I'm taking on my in laws bathroom vanity replacement project and they are set on the IKEA vanity and basin.
Hello @Jack151022,
Just a friendly reminder that any plumbing work must be carried out by a licensed plumber for safety and compliance.
The store carries the standard sized plumbing pipes and traps. They range from 32mm, 40mm and 50mm which most plumbers use. If the plumbing pieces you are using are compatible with the standard size's I've mentioned it should work. My best advice is to bring in your pipework and do a test fit with the plumbing pieces that are at the store.
Another work around is to use standard plug and waste fittings which will fit the plumbing pieces available at the store.
