I have a 6m x 3m garage with a concrete floor that is below house floor level, 250mm at one end, and 650mm at the garage door end, the fall ratio is around 1-10 (feet) My intentions are to make a floating timber floor with bearers and joists, however, i may have to add joists between bearers, as joists on top would be too high.
My questions: what piers could be used? Would i need ant hats? How many bearers? and what spacing using 140 x 45 pine? What sheeting to use 3m x 800mm yellow or red tongue? Would I need to knock out a couple of bricks for under floor ventilation (only the end wall is viable for this. (will download some photos and attach soon)
