want to install wire mesh to brick wall leaving a space between mesh and wall. Are there any spacers available?
Harry Wirth
Hi @harryp1,
These Jack Mesh Accessory Panel Clips are perfect for installing wire mesh to walls with a gap for things like climbing plants to utilise.
You can use Green Wall Plugs and 30mm Galvanised Button Head Screws to fix the panel clips to the wall.
If you wanted to increase the gap behind the clips, then you could always add a couple of Washers to act as spacers.
