I have a freestanding wardrobe split into vertical sections. One compartment measures 71 cm wide and ~40 cm deep overall, but the interior depth is asymmetric: the left inside face is recessed / only 24 cm deep while the right side is ~40-44 cm deep (photo attached). I want a simple insert to store folded clothes — material thickness ~10–15 mm (height not important).
I was inspired by this post here, and wanted to do something similar, or my initial idea was
Glue + nail a board to the left partition to bring it out from 24 cm → 40 cm so both sides are even.
Fix white batten strips (timber or MDF battens) to the sides/back to act as shelf supports/cleats.
Fit custom shelves / a shallow drawer stack (board thickness ~10–15 mm) that sit on the battens and are secured where needed.
I’m after practical feedback on whether this is sensible and safe — specifically:
Is glue + finishing nails reliable enough for attaching a 15 mm board to an existing thin partition (likely hollow / thin MDF)?
If not, what’s the best way to reinforce the left partition before adding the board?
Recommended adhesives and fasteners ?
Best batten/cleat options for a neat finish and solid load-bearing (timber batten dimensions, white)?
Any tips for finishing the seam/edge to look “built-in” (edge tape, silicone, small front trim)?
Would a free-standing shallow box or notched shelf be a safer/easier alternative given the thin partition?
I can drill into the back/right side and I don’t mind some permanent fixing, but I’d like to avoid wrecking the thin partition if possible. Any product links, quick how-to pointers or “don’t do this” warnings are welcome — thanks!
