looking for help and advise. Had a plumper come out and find an access point to the drains under some pavers.
what would I need to extend the access point up to level, so I wouldn’t have to dig it up. it’s a screw top cover access at the moment.
Hi @willdow,
Welcome to the Bunnings Workshop community, it's fantastic to have you join us, and many thanks for your question.
Unfortunately, as any alterations to a stormwater or sewer system are plumbing work requiring a licence, you would need to speak with a plumber for assistance.
A plumber would likely cut off the top of the pipe, then install a Slip Coupling in the correct diameter for the pipe, followed by a short length of PVC pipe to extend it to the correct level, then attach a Threaded Access Coupling with an Access Cap to the top.
They would likely use Red Priming Fluid and Blue Cement Solvent to glue the pieces together.
