Hi, I'm moving through my bathroom Reno project and my next hurdle is redoing the tiling. The substrate is a water resistant composite wood board (yellow tongue or something similar). I have cleaned up the surface after removing the old tiles and will reseal with water proofing. From my reading of the standards there needs to be a 1:80 - 1:100 fall from the highest point to the centre waste drain. This is going to create a some transition issues from hallway to bathroom, I'm aware of that however, in working it out what my fall will be and the height of the finished floor will be at the door my question is what will be my minimum depth of screed at the waste drain. Also, is Easy Mix the product I should be using for this? and can you buy screed guides to lay on the floor that have the correct fall or is that something I need to make up as a guide fro doing the job.
I've tried to find as much information as I can on this online but have not found anything that ties it all together.
Thank You
Danny
