Can you give me any idea of approx costs involved to lay drainage along back fence .
I thought perhaps with agi pipe fabric on top and blue metal or something the same on the top. approx 40 to 45 feet long.
Regards
Barbara
Hi @Barbara35,
A typical French drain, which is what you are describing, is roughly 300mm in diameter.
For a 40–45ft (roughly 14 metres) drainage trench, which is about 300 mm wide and deep, you’ll need roughly 1 cubic metre of drainage material.
These are the materials you will need-
1 x Vinidex 100mm x 20m Socked Slotted Draincoil
2 x GRUNT 1 x 10m Non Woven Geotextile Membrane Drain Mat Fabric
1 x cubic metre drainage gravel.
Your drain coil and fabric will cost approximately $230.
Drainage gravel can often be purchased in bulk from your local store's Special Orders desk. You would have to enquire as suppliers are regional and pricing varies, but a cubic metre of drainage gravel is usually somewhere between $100-$140.
All up, you would be looking at around $350 for materials.
If you needed someone to do the labour for you, you would have to get in touch with a landscaper or drainage plumber for a quote.
Let me know what you think, and if you have further questions, please don't hesitate to ask.
Hi Jacob,
Is drainage gravel the best to use. Do I need something not too fine so that it will drain better?
I thought I would leave the area above the agi pipe open with geotextile membrane on top on the gravel.
I have contacted a couple of people to give me a quote just thought I would get a rough idea of cost to go by.
If I allow $350 for materials any idea what labour would cost?
I appreciate your help again Jacob thank you
Kind Regards
Hi again any suggestions for trades to do this job?
Drainage gravel is what most drainage plumbers and landscapers would use, but in reality, pretty much any stones that are around 20mm would work.
The best way to make a drain of this nature is to dig the trench, lay the drainage mat into the trench, put in a layer of around 100mm of drainage gravel at the base, put your agi pipe in, then backfill around the sides and 50-100mm above the pipe. Once backfilled, the drainage mat can be folded over the top of the drainage gravel to create a channel that runs through the earth and is isolated from the soil around it. Having the drainage gravel above the pipe will help to protect the agi pipe from being crushed, while still allowing water to drain through it and into the agi pipe, where it will be taken away.
Unfortunately, I couldn't give you a rough estimate on labour costs as prices are incredibly variable. Your best option is to reach out to landscapers or drainage plumbers to get a quote. Check out How to find a tradesperson near you for some guidance.
I have had two different opinions from trades
1. Not to use agi pipe because it will let water also come out to use storm water pipe with slits that will only let water in.
2. The drainage mat is not needed under the agi pipe only over it when to metal is added to the top eg. metal agi pipe metal and drainage mat on top then metal on top of that.
I have had one quote and trades coming next week for more ideas and quotes.
So after I receive them I will have to compare apples with apples and make a decision.
Thanks Jacob
I have been on the phone to bunnings eastgardens for over 1 hour on hold and then hung up on an called again and still on hold
I want to find out how much 1 cubic metre of 20 ml blue metal would cost as well as delivery.
After completing this project with the gravel on top I am not going to put soil over it thought it would be better to just leave the gravel as water could drain through better.
Well I am still waiting on the line to get through hope I don't get cut off this time
Hi again Jacob,
It has been suggested that I use flat agi pipe which would collect the surface water better and have an open half round pipe along the top to collect the surface water to travel into the access pipe to stormwater. The problem is more with surface water I have to catch as it flows quickly over and through the garden.
Apologies for the delay. Have you managed to get in touch with the team at Bunnings Eastgarden?
It sounds like you've been given a variety of different advice, which makes it a bit difficult to compare.
Do you have any photos of the area where you are planning to install your drainage?
If the problem is more above-ground than below, channel drains tend to be a better option. A combination of the two, like you mentioned in your last comment, might be your best option.
I'll wait for your response to see what you think.
Just checking in to see how you went getting a quote for a cubic metre of blue metal from our Eastgarden warehouse.
If you'd like me to reach out to them to assist, I would be more than happy to do so.
Quotes still coming in and I am getting ideas.
the flat agi pipe I believe drains the water away quicker than the round.
I don't think bunnings have bulk blue metal.
Quotes for job vary from $1,400 to $2,900 to $4000 to $8000
Still got a couple more this week.
Still a bit of a quandry .
Lots to think about.
If speed of drainage is important, then flat agi pipe such as Megaflo Slotted Agi Pipe would certainly be worth considering.
I've also had a look, and our supplier BC Sands can supply BC Sands 1 Tonne 20mm Blue Metal Bulk Bag across NSW.
Keep us in the loop; we're happy to offer further guidance if you require it.
Hi again,
Thanks for all of your help Jacob I will keep in touch after all quotes are in.
Still getting quotes.
Think th way to go is the 250/300x250/300 trench with 20ml blue metal then agi pipe then drainage mat then blue metal leaving this open just blue metal on top.
Then getting 100 ml storm water pipes 3x6ft cutting to size and joining and cutting into half moon so that the bottom edge of pipe was at ground level and the top moon shape would collect any surface water coming through the joins in the treated pine sleepers. This pipe would be attached to the treated pine sleepers with stainless steel brackets and stainless steel screws and then joined into access point for stormwater in garden.
Still trying.
Hello @Barbara35
Just a friendly reminder that if you are planning on linking your agi-pipe drain to your stormwater drain you'll need the services of a plumber so that the connection will be safe and compliant to local council rules. My best advice is to make sure that your agi-pipe has the proper fall so that all the water it catches drains properly.
Of course a tradesperson will do the job not by myself
