Hey I am planning to put an inline fan with 2 intake ducts for our bathroom as we have a shower with double shower heads and the one fan isn't doing the exhausting enough steam from the second half of the room when the second shower head is running
Then I want to exhaust it all.out.the nearby eave
Question is, what would be the easiest way to feed through a 150mm duct from a edge ceiling or eave as they always have extremely low ceiling cavity at that spot
I need to have a duct go from the eave to the fan motor that I'll.place nearby in the ceiling which I should be able to reach if I commando crawl to it
Is there a trick or technique to feed ducting through those shallow ceilings areas?
I was thinking I could attach possibly 2.yellow tongue rods and tape those.to.the duct and feed it up.from the eave hole first and far ad I can go with it
Then go into the ceiling and connect it to the fan
